Todays Suggestion Stuck on REST?
Training Readiness states Well recovered @80
Recovery time 0hrs
HRV Balanced
Acute load in range
Sleep history good
Stress history low
Todays suggestion is rest again?  Its been stuck on REST for a few days even though all the other metrics are good?
I'm on beta 17.26 fw
I will still train as I feel good and my data confirms this, but I'm intrigued if anyone else has this issue?
Top Replies
All Replies
  • I have the same issue. Found this searching for the same issue… My metrics are also all fine. Only difference is that I am on a Fenix 6X (Saphire), which says V 26.00 (c7a16d5).
    Training as usual, and that shows as productive or maintaining. I did hit overreaching for a couple days last week - i was sick about 4 weeks ago which dropped my optimal training load zone, so that is lower than usual, and in getting back into my normal cadence, put me over the top (and unbalanced between high & low aerobic, but this has balanced back since then.
    No training plan loaded, just have been using the suggested runs as a general guide, but it's saying "today is a scheduled rest day"…
    Dave
  • Actually, after searching a bit more, came across this thread in the Fenix forum… Not sure if it will work for you, but could be a similar fix.
  • Lets go ahead and use Rest day bug as our main thread so the topic has better visibility. Thank you!
