[email protected] - WiFi Connect Error
The issue suddenly started. Same network environment went from normal connection to error 300 and then just to spinning wheel being stuck on Searching for Network.
I tried the steps outlined in one thread:
1) Adding through Garmin Connect App
Additional attempts:
2) Adding over phone
3) Adding over watch
4) Resetting the Watch
5) Manually adjusting Router Channel to 9 and making sure that the control channels are in range of 1-11 and not 12/13.
6) Trying the hotspot on iOS and Android with or without VPN
7) Alternative WiFi Networks
Everything comes up the same at the moment.
Not sure if the beta addresses this issue or not, but can't directly download for obvious reasons.
Can the beta be installed via garmin express app?
Max
  • Additional troubleshooting steps taken:
    - Remove Phone Pairing
    - Remove Wifi
    - Restart the device
    - Add wifi over Garmin Express App v7.17.3
    Done on Asus ROG M16 running latest Win11
  • Last night a weird thing happened.
    I disconnected the watch from phone over the long press power button->Phone and left wifi on.
    When I woke up in the morning the watch drained 30% battery. That was strange so I went and checked the update folder.
    Based onnthe battery drain the watch was trying all nigjt long it seems and managed to download and prepare the update.
    I installed it.
    Still wifi spins into oblivion. Thinking
    Not sure what's happening.
    Max
