Hello folks!
I've had the Forerunner 965 (and also an Edge 830) for a few weeks. The values for the heart rate zones are so questionable that I have to investigate:
Here is the list of my questions:
1. With the Forerunner, there are sub-items "Zones" and "Sport heart rate" in the Garmin Connect app in the user profile / heart rate and power zones / heart rate.
a) What is the difference? What is "Ranges / Default" for?
b) Why are the % values for "Standard" completely different from the % values for the individual sports?
2. When setting the heart rate zone by HR Reserve, extremely low % values are displayed. This is completely illogical, because HRR is HR max minus HR rest. This means that HRR is logically a lower value than HR max, so the % values cannot be so low. It calculates completely wrong values with it.
3. When I calculate the HR zones for cycling in Garmin Connect Web for the Edge 830, Garmin suddenly takes completely different % values than are used with the Forerunner. That doesn't add up at all. One should assume that the HR zones are calculated uniformly - regardless of which device you set them with. At Garmin, the Forerunner division doesn't seem to know what the Edge division is doing and vice versa.
4. When I do a heart rate based workout with the Forerunner, there is another value that I don't understand below the heart rate and the time (the countdown). I have no idea what this value (which seems to me to rise irregularly every now and then) means. I couldn't find anything about it on the web either.
5. And last but not least, a point that is not a question, but just expresses my amazement at what Garmin produces: if you download a triathlon training plan, the training zones listed there (No. 1, 2, 3, 4 .. .) do not match the Garmin zones. What is in the training plan 1 corresponds to zone 2 in Garmin. Therefore, in order to be able to use the plan, you have to edit each individual training session and change the zone from 1 to 2, from 2 to 3 etc. everywhere. It's just unbelievable that Garmin doesn't make it and don't seem to care to fix that.
I hope you can give me answers to these questions. Thank you very much.
