Hi,
Since I bought my FR965, I no more have the segment screen showing up whenever I'm following one. You know that screen where you see yourself compared to the one behind and in front of you?
Any idea?
Thanks.
Hi,
Any idea?
Thanks.
I haven't been able to see ANY of my Garmin segments on my 965 since moving from the 945. It's like the feature is not there anymore - the manual (linked below) only references Strava segments. Not sure what I am supposed to do.
The reference is for both Garmin and Strava segments.
It just has an additional paragraph detailing how to get Strava segments.
Do you have segments alerts turned on in the activity?
If you choose (say) the RUN activity , in the settings make sure Segment Alerts are ON
In my case I have two RUN activities set up , one called RUN Quiet with the Segment Alerts OFF and one called RUN Segment with the Segment Alerts ON , so that I can choose as sometimes one doesn't want to be disturbed all the time
Also on the Connect app , Under Training and Planning , Segments , do you see your Garmin Segments listed there?
You should also be able to see the Segments on the watch in the Activity by holding the MENU button and selecting training when in the Activity start screen, Segments should be on of the items on the list there
Okay it worked! I got prompted on some of my old segments, which is the first I've seen with this 965.
HOWEVER, similar to the OPs issue, it did not automatically switch to the "segment" data field/screen like my old watch did. I don't see any settings under Segments to adjust this (only the "Auto Effort" toggle), and I don't see anything in the manual linked above. What am I missing?
