Air Quality in weather no show result, alerady check location permission and all point concern (app , weather, phone) but still not show 955 and 965!
Is it a bug or will it be fixed?
All,
Please see this Note at the bottom of Weather Widget Displays Wrong Information on My Garmin Device:
"Air Quality data will display on compatible devices that are located in the continental United…
Kraisun
Can you upload a picture of your Air Quality screen? Select your Weather glance, and then scroll down 3 times.
Mine shows although it’s not MODERATE currently it’s a red warning level.
Same here in Switzerland.
Same here. No air quality on my watch. I live in the Netherlands. This info is available. My iPhone shows air quality.
Same here, Northern Italy
S.M.R. said:it’s a red warning level.
I think the red warning is for UV, which is high in your example.
Same here in Finland. Air quality (= ilman laatu) is not showing.
In the Netherlands also not showing on my FR965 connected to Google Pixel 6 Smartphone.
Mine only shows humidity, despite previously showing all fields, and has had the wrong location since I got it which won't change. Every permission granted to the app, reset it a few times, doesn't help
I just checked & no air quality either in Ireland.
