Hello, with version 4.19 installed, I experienced the following two scenarios.
1) touchscreen disabled for general use + enabled for all activities. Start activity running + check touchscreen is enabled ( hot keys ). Touchscreen works fine with change pages, but whilst selecting maps + touch it, touchscreen does not seem to work ( e.g. can not move around map ), despite you enable/disable touchscreen with hot keys
2) touchscreen enabled for general use + disabled for all activities. Start activity running + check touchscreen is disabled ( hot keys ). Despite touchscreen is disabled, you can use it to change pages or select maps + touch the screen + move around the map, despite you enable/disable touchscreen with hot keys
Is that the way touchscreen is supposed to work ?
