Map blanking out on move with physical buttons in Navigation
If I use the maps function from Map I can pan around with the touchscreen or physical or on-screen buttons to move the map just fine, but if I open the map in Navigation and do the same using the physical buttons to pan cause the map display to blank out for a second or two while it loads the updated map- this doesn't happen using the touchscreen nav buttons, and is happening on all maps installed. I'm not on the beta
Anyone else confirm this/know a fix?
edit: happens on some maps when using the on-screen buttons too in navigation mode
