So this isn't really the fault of the 965 necessarily but I'm trying to understand why my cycling activities where I don't use a power meter score so low compared to those that do. I know the device is probably using HR as a stand-in for Power, but I must have a setting incorrect as the scores are just too low to be reasonable.
For example, I can average a higher avg HR for a ride withOUT the power meter but the Load will be 50% of the load that does use the power meter. I have a lot of examples of this, so it's consistant at least.
In my User Profile for the 965 I've set my HR zones to what I think is reasonable, even dropping the LTHR somewhat BELOW what it actually is to try to get these Load scores to balance out. For example, today at lunch I did a 50min ride averaging nearly my LTHR and the Load was less at a per-hour rate than a very easy ride I did with the Power meter a week prior.
I'm not sure what else I can do? Suggestions?
