Forerunner 965 keeps on going into Power Save or Sleep mode despite a 73 percent battery and battery saver feature not enabled. Has anyone else had this issue? Really annoying to have my watch go to sleep mode every 5 minutes!
Hello friends, seems that i found the solution to the problem.
The root cause seems to be the initial setting in Garmin connect app when asking what are the sleeping hours - pay attention to what you set there, i believe that i set 23:00 to 6:00 but after suffering from the same situation as you all, i investigated different settings in the watch and finally saw that the sleep schedule was set to 11:00 to 6:00 instead 23:00 to 6:00 so maybe the conversion of hours from the app to the watch was the reason, after changing the setting manually in the watch the problem solved!!
Hope it helps you too, let me know
