Gesture control is broken
If I disable gesture control, is still works 4 to 5 times, other times the setting doesn't make any difference, I have to restart the watch so that the setting takes effect.
Why do I need to disable the gesture on a watch like this? Because it works improperly. At certain angles, if I rest my hand on a desk or on my belly, the watch will think the angle it is counts as gesture and it will keep toggling the screen on, toggle off for less than a second, then turn back on, continuously in a loop.
The most annoying thing was when I left my watch on a towel, that had a slight incline (maybe 20 to 30 degrees), stationary (so it wasn't moving at all), and the warch kept doing the same behaviour as above, indefinetly. I thought about turning it with the face down, to stop doing that, but no, it doesn't stop it.
How does this feature work, if it works at all? My girlfriend has a Venu 2s, that works flawlesly with the wake-up gesture, and mine keeps flashing the screen on almost any angle. It's so annoying and it drains the battery. It's basically a worse implementation than AOD.
SW. Ver. 3.58
