Apps stop on their own after 1 minute of use.. watch them turns off and on, on its own… happens 15 times in the gym today… cycling and elliptical apps… probably all of them but only did those two today… needs to be fixed. Thanks
RBD1979 Since you are still noticing concerns after trying all of the troubleshooting tips, please contact your local Product Support team for assistance with your available options!
Has anyone noticed this today?
RBD1979 For the watch rebooting, please plug the watch into an outlet then power cycle the watch. After that, unplug it from the outlet and monitor the watch to see if that helps!
If you still need help…
Yeah, I was using the elliptical and cycling app/widget/ not sure exactly what it’s called… trying to record my workout in the gym … literally every minute it stopped… I had to restart it… after 40 minutes…
If you still need help, can you clarify when you say Apps are you talking about your Activities on your watch?
Yeah, I was using the elliptical and cycling app/widget/ not sure exactly what it’s called… trying to record my workout in the gym … literally every minute it stopped… I had to restart it… after 40 minutes of working out… I had about 11 minutes of workout saved on my watch because I was tired of starting it every minute… and it was also rebooting on its own… never happened before, so it was weird… but definitely needs to be looked at… love my watch but obviously a problem… would think software … nothing wrong with watch!
Activities yes
Happened again while running today… just once though… but still…something is clearly off…
Today same thing happened on treadmill… shut off and turns back on,shuts the timer off, doesn’t record activity correctly… please look into this.its every day and activitynow
Yes the activities
Thanks for letting us know this is still happening. Let's also check to see if any software updates are available for your Forerunner. I recommend using Garmin Express, which is a desktop application available as a free download here: https://garmin.com/express
If the crashes continue, I also recommend uninstalling any Connect IQ content that you may have loaded, in case that is the culprit. For steps on how to do that, use this link.
watch completely shut off yesterday and wouldn’t let me turn it back on until I plugged into wall/outlet…when I was just out for a run… today it shut off while using the running activities .. came back on fortunately but was still not able to get all info from run… this is starting to get a bit long really…
Also, I have not downloaded any IQ content..
