I see that with this new firmware 24.12 my 955 Solar don't calibrate quote every start of activity outdoor like before, and I have option activate for do it. I run near to sea with a quote like -65m without any correction when I start to run. Why?
It seems that since late May all the runs that I started after having been at a high floor all day, retain the high altitude at start of the run, go up a bit and then slowly adjust to the correct street level altitude.
Since you mentioned this, I am using manual calibration before my runs, and that fixes it.
NB manual calibration to a negative altitude is not possible on modern devices, so you will have to use calibrate with DEM.
I guess that waiting for the "auto-calibrate at start" (that is still a by default enable feature AFAIK) either does not work anymore, or needs more than a few seconds. I have.little free time, I start my run immediately and slow jog the first km as a warmup.
