Screen freeze and crashes
Since one week my forerunner 955 is crashing 1 or 2 times each day, am I the only one in this situation? And sometimes I can't turn it on back without plug it.
    0 Former Member 6 months ago
    Many possible causes, might be a weak battery or corrupt file.
    Contact Garmin Support if you want it investigated, or try some 'first aid' yourself; do a simple reset (on/off), if no luck, sync via Express, do a full reset, sync again to get (most) of your settings back. If that does make a file backup on a computer, then delete possibly corrupt FIT files in the Activities and Workouts folders, consult Garmin Support again if that does not work, there may be additional files that should be deleted.
