I've had my 955 for a couple of years now, but at some point in the past year I've become aware that the navigation feature just has a mind of its own. I'm fairly sure it didn't used to have these problems, but can't go back in time to check old software versions. The two main issues I'm having are:
- I often plan hiking routes that don't always follow paths. When I import them to the Garmin Explore app and save them as a course the GPS trace looks correct. However, when I go to navigate the course using my watch the route has been snapped to the nearest path, which is not what i want. I've checked that 'lock on road' is turned off in the watches map settings, and double checked that the course hasn't changed in Garmin Explore, but it keeps doing this. Even though I import the GPS files from another app I've also tried changing the 'routing options' in explore to 'freehand' before saving it, but doesn't seem to make a difference. I literally just want to follow the GPS coordinates that I planned in my route, but the watch wants to be clever about it - is there a way to stop this?
- Sometimes the navigation on my watch takes a completely different path to the one I planned, even when my routes are following paths. I noticed this the other day, that coming up to a junction my watch was saying to go right, but I know the route I planned was going left. Again I double checked this on the course I'd saved in the Garmin Explore app and that was correct, but my watch made an executive decision to change my route! If it makes any difference I was following the route in reverse this time. Again, I just want my watch to follow the GPS points I put on the route, not make up its own idea of where it thinks I want to go.
Also, possibly related I've noticed that sometimes when tracking an activity if I look at the map my track is in the correct place, but my current location seems to be snapped to the nearest path even though I've double checked that lock on road is turned off. This can be quite confusing if I don't realise what's going on.
Both watch and app are fully up to date.
See an example below, where the route I've planned should take me left at a junction, but my watch is trying to make me take the right fork (and has snapped the route to a path too):
And an example from last year of the watch snapping my location to the nearest path incorrectly (it should be to the left next to the fence line where my track is shown correctly):
Basically was wondering if these are known issues, and if there's any way to prevent this behaviour?
