Instable connection to smart trainer with Ant+ after firmware update to 21.22
I have used my Garmin Forerunner 955 to control my smart trainer elite suito.
The connection via ant+ worked flawless for the last year. After Firmware update of FR 955 to 21.22, the connection is very instable and the 955 is now useless as a Controller for the smarttrainer.
Description of the procedure:
  • The smarttrainer is found by the 955 immediately.
  • The connection is established and the smart trainer indicates a ant+ connection.
  • After start of the Workout, the smart trainer indicates that ant+ connection is lost and the power is no longer controlled by the 955. The 955 however does not indicates a lost connection.
  • The connection will not be re-established automatically.
What i have done already to fix the problem without any success:
  • Reboot FR955 and smart trainer
  • Factory reset of FR955
  • Update smart trainer Firmware
  • Smart trainer works flawless with BT comnection to Smartphone
  • FR955 has same connection issues with other smart trainer (also elite suito)
Is this an issue with 21.22 formware  of the 955 or is it a hardware problem with my specific FR955.
  • Did you check the stand-alone mode on your trainer?
    I had a similar issue, open a ticket with Elite, and they provided me with this link:
    https://elitesrl.zendesk.com/hc/en-us/articles/6877833313938-Stand-alone-mode-for-interactive-trainers
    I turned off the plugged option, and it's been working flawlessly since then.
  • Hey many thanks for this advice. Will try if this helps and report here if this solves my issues.
  • I have testet it today again witb no success.
    My e-training app reports an error when i try to enter the Parameter "stand alone/ plugged in trainer"
    I have tested it with both, the Android App and the Windows PC App from elite. All other parameter could be accesed and modified.
    What i have tested now as well, is a connection with my Windows PC running mywoosh together with an ant+ dongle. This worked flawless without any Interuption.
    So my conclusion is again, that either the New fr955 Firmware or the fr955 Hardware is the problem.
    Has anyone else problems with ant+ connection to a smart trainer with the new garmin firmware?
  • I learned that Elite trainers expect more frequent active control from ant+ devices than the forerunner sends.
    That was the reason for changing the plugged stand-alone setting.
    I have no issues with my watch.
    I suggest you open a ticket with Elite to determine what's happening on both sides.
  • Elite Support provided a json file as a work around for the known problem that the standalone Feature can not be deactivated.
    It works now. Power is adjusted again using the garmin watch. Even though the ant+ connection is still instable (green ant+ light flashing all the time).
