Forerunner 955 - VO2Max-Curve - Switch between Bike and Run
Hello,
i find the glance for the VO2Max-Curve very interesting (where you see the progression of the last 4 weeks).
This glance is available on the Forerunner 955 for cycling and for running (i need both).
Unfortunately, switching between both curves is not possible.
I don't know, what's the algorithm behind, in my experience the shown graph is dependent on the workload of each discipline: If you have "more" bike workouts, then the bike VO2Max-Curve for Biking is shown, if you have "more" Run-Workouts, the VO2Max-Curve for Running is shown.
Is it possible, to switch between both curves? Can i request a feature update here?
BR,
Marc
  • If I go to the training status glance and drill into the VO2, it shows the VO2 of the LAST sport (with no toggle). It does not show the highest VO2. For example, my VO2max from cycling today is shown, which is lower than the one I have for running which I cannot see.
    yes, it would be good to be able to switch to see vo2max from all relevant sports
