The new update and the way you select reps and weight is a godsend. Can we get a full channellog of all the changes? The sticky seems to be missing alot.
What did they change that you like, Jeffrey? I've had issues with his.
When done with a set and you push the button it now shows reps and weight.
Up and down change the reps, with a push of the start button it goes to weight.
If you push the down arrow you can select from a list of recent weights.
If you push up, it takes you to a screen that allows you to change the weight.
The weight is now adjustable by 0-99 instead of 0-9 too.
This set up makes it much easier if do a circuit or a superset.
