I just noticed when looking at the map there's a digital inner ring that's there now? What purpose is that for?
Exactly! This is it. Try to move map a bit and circle should vanish and be replaced with small dash at the bottom of the screen.
I assume you have added Map to your Data Screens for Run Activity. The same view should be just for Map app.
With latest beta 21.18 I have an extra Compass icon, which after tap, change screen orientation…
Could you post screenshot from watch?
Capturing a Screenshot on a Garmin Watch | Garmin Customer Support
If we are talking about that crescent at the top, then if you move map away from your current position it will still show at the bottom.
For me this one is just X meter radius from your standpoint
Thanks, that is a good fix, as soon as I move the map the ring is gone and the scale indicator is back. Only now there is a display at the bottom listing the position of whatever I touched on the map (I don't see the need for that, I always used long-press start to see more information on a map point). l BTW my watch is stuck on 21.14 so maybe it looks different on mine, but it works!
That's why I have asked for screenshot.
And that second part of your comment is (I guess) related to that City Navigation thing.
And I guess again, it requires GPS fix before will be able to Calculate Route correctly. Otherwise it is just stuck in waiting loop like it was mentioned with Navigation and Moon phase City Spell search.
Not the topic of this discussion, but route calculation times out for me, also with GPS fix. I hope Navigate to Start still works, will try today.
BTW posting pictures did not work for me lately, don't know if that is the same for others.
GPS Fix - I have just verified that. Without - timeout, with fixed signal takes several looong seconds to calculate but eventually I have Route.
My sequence: Start -> Map (not Run, Walk or Navigate) -> Move map with finger -> Touch something on the screen -> Tap on the bottom part of Screen -> Confirm interested point on next screen either with Tap or Start button -> Go -> and only now select Activity -> Wait until Route is calculated (here if there is no GPS Fix it will timeout)
I will add that comment about GPS Fix to Bug report
