FR955 not getting GPS
Fr955 not getting gps signal no matter what I do. It used to aquire gps in seconds, now it won't get gps ever. I've factory reset it, synced with garmin app countless times, synced with garmin express countless times, deleted RemoteSW and CPE files and nothing works. I've left it outside under the stars to catch GPS for up to 30min multiple times, no gps. The only strange thing I have noticed is that somrtimes when I do my run without gps being aquired, the distance can be fairly accurate for a few km's then fail. Only solution I see is to get a new watch. Any help?
  • I have something similar. Since few weeks was worse and worse. At the beginning, part of the run wasn't saved, then was correct distance and no map displayed, finally, when I did multiple full reset, there is no GPS at all. I have watch always connected, running to/from work everyday same route. Non-stop synchronized with Garmin connect on my mobile and now hundred times with Garmin Express on PC.
  • Had the same issue recently. I had switched to All + Multi-Band. Works perfect for me. I didn't notice any abnormal battery drain.
    Go to Menu (middle left button) -> Settings -> Satellites -> All + Multi-Band
