I just got a Concept2 Rowerg with PM5 unit and had a few questions about broadcasting, which I’m unfamiliar with.
- Two devices show up on the PM5 unit when I set-up a broadcasting connection. One is Forerunner and the other is ANT+[id]. Why two? I would have assumed that the Forerunner option was a BT connection but I’m sure broadcasting only works over ANT+?
- If I wear a HRM Pro Plus chest trap connected to the watch, will this be broadcasted? (Source switching off)
- If I use a smart trainer connection (FE-C) which does work and receives the work out data, I would also need to connect HRM to the unit to display HR. Will this data also be sent to the watch - given HRM is also connected to the watch directly? I’m concerned about duplicate or competing data.
Thanks.
