Before update FW. Normal HR
Today I was on individual running race 5km. Speed and result same on one week ago ~
But HR is wrong
But HR is wrong
the problem persists. Today I did acceleration and the first acceleration showed a true result of 180 beats per minute. the rest are incorrect!
Maybe someone is experiencing similar problems?
Using following data field from Garmin Connect IQ apps.garmin.com/.../a461bc0d-828d-47c8-a4a5-8d014b5fedc9 need to unpair the chest HRM then watch uses the OHR and the auxiliary app 'finds' and uses the…
Same problem, using both OHR and Garmin HRM PRO chest strap (configured as auxiliary HR so can view/record both at same time), OHR under-reads by 30bpm then suddenly 'acquires' after around 10 minutes…
I assume the first graph is the wrong one where the HR suddenly steps up from 160 to 185 just before the 8 minute mark?
Do you have the cadence graph for that one?
you are partially right. There are also questions about the first graph. but at least it shows the work of the heart within my real working limits at an average pace of 4:00, which is 180 beats per minute
Same problem, using both OHR and Garmin HRM PRO chest strap (configured as auxiliary HR so can view/record both at same time), OHR under-reads by 30bpm then suddenly 'acquires' after around 10 minutes, prior to v18.22 it used to acquired within about 1 minute which is much more acceptable. Currently trying to find a way to retrograde to v18.15 beta which looks like it might be the last version before it broke...
How do you configure chest strap as auxiliary and record both strap and OHR with the watch?
Using following data field from Garmin Connect IQ apps.garmin.com/.../a461bc0d-828d-47c8-a4a5-8d014b5fedc9 need to unpair the chest HRM then watch uses the OHR and the auxiliary app 'finds' and uses the chest HR automagically and presenting it as aux HR, can create a screen with both, and both are recorded and can be viewed in chart afterwards, it is enlightening!
Just recorded this tonight, OHR took about 18 min to acquire
