[18.23] [BUG] When 2 CIQ fields are selected (the max amount), other CIQ fields are unavailable, even when replacing an existing CIQ field
I'm reporting this bug here because the 955 beta forums are currently locked (ig it makes sense, as there are no betas at the moment.)
For what it's worth, I've mentioned it before -- it's been around for a while.
Firmware version: 18.23
Recreation procedure:
1) Install 3 (or more) CIQ data field apps. Let's call them apps A, B and C for the purposes of this bug report
2) Assign app A to a data field (call it slot 1)
3) Assign app B to a data field (call it slot 2). Now the 2 field maximum limit has been reached
4) Now edit either slot 1 or slot 2, and try to select another CIQ field (e.g. C). You will see that only A and B (the existing selected apps) are listed under "Connect IQ Fields". This is obviously intentional (it makes sense if you are editing *other slots*), but it doesn't make sense when you edit a slot that is already occupied by a Connect IQ field. For example, replacing app A with app C will not cause the 2 field limit to be broken
Expected behavior:
4) When I try to edit slot 1 or slot 2 (currently occupied by CIQ data field apps), I am presented with the list of *all* installed CIQ data fields, not just the 2 data fields that are currently selected
Workaround:
Before editing slot 1 or slot 2, I have to change either of them to a non-CIQ field (which brings the total number of CIQ fields to 1). At this point, the watch will display the list of *all* CIQ fields regardless of which slot I'm editing.
  • Also, I'm still seeing the bug where one of your CIQ data fields may crash when you change the other one. This may be related to one of the fields being Stryd Zones. The workaround is to exit the activity and re-open it. (In the past that hasn't worked, but it seems to work now.)
    EDIT: in one case, the workaround didn’t work, as when I exited the activity and re-opened it, the previous CIQ data field (from before the crash) was in the slot I had changed, instead of the new CIQ field (which had crashed originally).
  • I have never been able to view all of my CIQ downloaded apps through Garmin Connect. I see the first 2 I downloaded and the rest don't show. Ive been able to change through the watch but not always.
