Continue until the lap button is pressed does not work on a workout. It continues until you finish and you get lots of laps instead. Old problem, no fix from Garmin. Så om man vill fortsätta springa efter ett Garmin träningspass så får man stoppa hela aktiviteten och börja om med ett nytt. So if you want to continue running after a Garmin training session, you have to stop the entire activity and start over with a new one. Why doesn't it work on the Forerunner 955 when it worked on the Fenix 6 Pro? The only solution is to fiddle with the settings and remove the option for manual lap completely.
