I can see that this is somewhat of a persistent problem - Is there a fix for it?
Per my pictures below, I have auto-detection, but my watch believes it is a manual entry, and on Gramin Connect, nothing happens.
Thanks!
Thanks!
Hurray - finally! An update on all parameters :-) What triggered it ?- I have no clue, but the graph from GC speaks for itself!
Thanks for all the comments and good suggestions
It did not make any difference to me; It was a one-off. You get one update - that's it.
Before it broke - you could follow and see your updates, like in the picture below - the empty BPM field seems…
Went out for a run today: 12 km total with 2x3k at slightly above threshold and got this when saving the run:
Can confirm that it also showed up in Connect.
you are correct as it is anyway a one time update of LTH and than never update again. I have this problem since Forerunner 945 and now also on 955 so it is an old problem to be addressed
You get this update doing a normal Running activity or performing a LTH test manually? Thanks!
Regular running activity, and before it broke, you would get updates (up and down) every time there was a change.
Thank you very much for your response. It has worked fine for me so far, but I want to test to see if it still works that way, that's why I asked you. Thanks!
