F955 Solar | v17.24 | There is no backlight setting option in the menu.
Hi Everyone!
I recently bought an F955 Solar watch. Yesterday I upgraded to version 17.24. I am trying to customize the settings and I just noticed that there is no backlight setting option in the menu.
There are many posts here on the forum about the backlight malfunctioning, but I can't find one where it is missing from the menu.
The backlight can't be adjusted on the F955?
Thanks!
  • It seems it has disappeared from menu System -> Backlight and now it is set under System -> Display
  • You can go to Settings > System > Display and there you can chose you preferred setting for
    • During activity
    • General use
    • During sleep
    Under the set Brightness.
    You can also add a Control to your menu from:
    Settings > System > Appearance > Controls > Add New > Backlight to have and easy access to this from the Controls menu.
