Hello,
I understand that the wrist heart rate is set to conserve power and so if you do not start an activity, it doesn't measure as often as if you have started an activity. We all want longer battery life. Agreed
If I go on a walk without starting an activity, after a while I see the heart rate on the face of the watch going up (120 for example instead of 65 when not walking). This is what I would expect. I do not expect the watch to react immediately to my increased heart rate (because we are saving power and I did NOT start an activity). All good here
BUT. I often do stairmasters at the gym without starting an activity. I do stairmaster hard. For 20-30 minutes. I am totally drenched, I am breathing hard. Every time the watch doesn't bulge from 75ish bpm. My real heart rate is 168-180 confirmed by myself counting on my throat (for 10sec or 30 or anything else) and by the sensors on the stairmaster itself
The question is not about discussing if I am making a mistake counting the pulses myself or if the sensor on the stairmaster is not accurate, I am 100% sure that I am well above 160bpm
Is the wrist sensor not picking up the higher heart rate because I am not moving my arms? Is that linked? A higher heart rate when walking is detected. It is not on the stairmaster. Even if the watch is not measuring as often as it does during an activity, 20-30 minutes is PLENTY of time for the watch to see the change. The moment I start an activity (indoor bike for example) it jumps up to 170ish in few seconds
Garmin-Sierra, can you confirm if the wrist sensor (with no activity started) doesn't measure anything if there is no movement detected, even with an obvious difference as in the case above?
Yes, I obviously can start an activity, but that is not what the question is about. If I go running or walking without starting the activity, the HR on the face of the watch works (even if slow response and not as accurate). On the stairmasters it doesn't.
It is a curiosity and not super critical but it is obviously wrong and it messes up also calorie counting/body battery etc etc (if you care about it)
thank you!
