Open Water double distance
When I use my FR955 for Open water swims the GPS track looks fine but the distance is doubled. I could understand that it could struggle with keeping a GPS signal, but as this is not the case I cannot understand how the watch can be so much off. It sucks big time as it screws up all the swim related metrics. What do I need to change in the settings to avoid this?
  • Hi,
    I have the same issue on FR955, on both versions 15.19 and 16.17.
    When activity is exported into Google Maps or Google Earth distance is different from Garmin, about 40% shorter.
    Looks like the bug is not in GPS or GPS recording but in UI distance calculation.
    , can you please look at the issue.
    Thank you.
    P.S: Interesting issue raises, if training affect and other metrics are calculated based on distance, it is a whole another issue.
  • Thank you for taking part in the Forum thread. In order to further assist, we'd like to gather more information:
    • Do we have permission to email you?
    • Do we have permission to view you Connect account?
    • What country do you live in?
  • Hello.
    Yes, yes, Israel.
    Please be aware I had manually fixed the distance. The rest of the data is intact.
    Thank you.
  • Although the requested permission to access account is not directed towards me you are more than welcome to email me, access my Connect account and I live in Germany for the record.
    As with Leon I also manually changed the distance.
    The issue is quite annoying as it also means that the energy consumption is way off as the swim speed is super fast
  • Hello,
    I think I had found a remedy. It worked with 100% accuracy today - Garmin distance was perfectly matched with Google Maps.
    Here is what I did:
    1. Disabled auto lap and lap button. Inside open water settings menu, there is "Laps". I turned off everything.
    2. Waited for GPS lock, before starting the activity.
    There is a semicircle on the top of the screen when entering into activity, it is white and red at the begging, I had waited for it to become green.
     I'm happy now.
    Good weekend for everyone.
