Custom Workout Not Appearing
Hi all,I've had my 955 for a week after my 945 died. However I am having an issue with custom workouts created in Garmin Connect. I am creating a bike workout to be done on my indoor trainer but it won't show on my 955, It shows on my Edge and under normal 'bike' profile on my 955 but not under Indoor bike thus i can't follow the workout on my 955. I can't find a way of moving the workout to Indoor bike nor creating it as an indoor bike workout....am i missing something basic? I'm pretty sure my workouts all appeared on my 945.
Thanks for any advice in advance
  • Sorry--no advice and this seems like a bug introduced in 16.17. I'm having a similar problem with run workouts: I've created custom "Run" workouts that no longer appear on my watch (955) when doing a "Trail Run" activity. However, they do appear when doing a "Run" activity. This just started for me after upgrading to 16.17--I did not have this issue under the previous firmware version (15.19).
  • HI, same here with my FR955 16.17. Workouts appear only within the "Run" activity, not in the "Trail Run". Only since 16.17.
  • Yep, started with the last update. None of the indoor workouts are appearing..neither bike nor run. I hope they fix this rather sooner than later!
  • In the past, I was able to use the Garmin Connect app,  go to More | Training & Planning | Workouts.  I could create workouts, save the workouts and then click the icon to send the workout to my watch.  I could see these workouts under Activities such as Run, Trail Run, and Treadmill.
    This was working great, until the most recent version of the watch software was pushed to the watch.
    Now, my workouts only show up under Run.
    If I go to Trail Run or Treadmill, and select Training | Workouts I only have two options.  One is "Daily Suggestions" and the other says "Build in Garmin Connect".
    The problem is even if I build a Workout in Garmin Connect it's still not getting pushed back to Trail Run or Treadmill;  it's only getting pushed to Run.
    Happy to work with anyone in dev to get this sorted out.
    Thank you!
    Virginia Leandro
    Device: Forerunner 955
    Garmin Connect Version: 4.70.1.4
  • On my watch (Instinct 2), I do see running workouts created on the app also in the menu of Treadmill, Trail Run, etc., so it does not look like a problem of the app. I recommend asking on the forum of Forerunner 955 ( https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-955-series ) whether other owners of that model experience the same problem. Or contact the Product Support at https://support.garmin.com if you do not get any answer from other users of FR955.
  • Just wanna add comment to this bug as I was about to post when I noticed this thread. Experiencing the same, none of mye custom running workouts appear when using threadmill activity :/
    Hoping Garmin will fix this soon!
  • I am having the exact same issue on my Forerunner 955
  • All,
    We are aware and apologize for this disruption. While we investigate, please follow this work around: Place the workout on your Garmin Connect calendar so it is pushed to the device upon accessing the profile. The watch will still prompt you to complete the workout, and it can be done so from your desired activity profile.
  • I found another workaround in the meantime.
    From Activities, go to Workouts | My Workouts.  Select your workout and (Do Workout) and then you can associated it with Run, Treadmill, Trail Run, etc.
    But yeah...Garmin confirmed a defect....
  • Have been having this same issue for past few days. Hopefully Garmin has a fix shortly and can keep us all updated.
