Current weather jumps.
Hi,
I see wierd jumps in current temperature that Garmin shows (watchface).
I wake up, 16 oC. Then in an hour it is 20oC (reasonable). Get in a car - suddenly it is 15 oC and then back to 22oC (reasonable again).
I set up Garmin to get data from a fixed location, not actual location, so that's not an issue.
Watchface is a stock one.
Any way to fix that?
Looks like the issue is there for quite some time (here's an example forums.garmin.com/.../weather-widget-temperature-is-wrong
Any ideas?
