Why is the avg GC Time Balance field always empty??????
All,
jambongris is correct. We do have a report regarding this, and a fix is going to be included in an upcoming software update. A release date has not been set yet.
Keep in mind that you must be using…
...or the running dynamics pod. And not all HRM straps have the necessary accelerometers to measure it. The Garmin HRM-Dual doesn't, for instance.
I think it’s a known bug. It shows up sporadically for me when I wear my HRM Pro+.
(If you’re only wearing the watch then it won’t show up at all as the watch isn’t currently capable of measuring…
Also (this is based on my own experience with 965 and HRM Pro+), in addition to getting ground contact balance, the quality of the other running dynamics metrics is better with the HRM (which is to be expected, since the strap measures movement at the torso, instead of the end of a moving arm).
All,
Keep in mind that you must be using an HRM-Pro/Pro-Plus, HRM-Run, or HRM-Tri heart rate monitor, or a Running Dynamics Pod with your device.
