Can someone help provide clarity about some of the settings on the watch, and whether I have them configured properly? I have a HRM-Pro+ strap which I obtained a few weeks ago and I use that on all runs.
- Automatic MaxHR and LTHR turned ON
- MaxHR is 186bpm (which conforms to the default age-based calculation, and is decently accurate based on the actual max HR I have observed during some short sprints)
- LTHR is 167bpm (discussion below)
- HR Zones are based on %LTHR with default percentage bins
- SW/FW 15.19
The LTHR of 167bpm was "guesstimated" by the watch before I got the HRM strap and it is 90% of the MaxHR. When I got the HRM strap, I did the LTHR test (15 min warmup, then a series of 4 minute intervals of increasing HR: 139, 153, 163, 172bpm) and at the end it said that LTHR was calculated as 167bpm. So it could be that I fall well into the middle of the distribution of human physiology and default values are representative for me.
But, I have never seen the MaxHR or LTHR values change. Connect (app and website) say that LTHR is a manually set value of 167bpm.
Questions
- Some forum posts here say that the automatic MaxHR and LTHR will only ever increase, and never decrease, as far as I can understand. So if one suspects that their true values are lower than the presently set ones, they should manually set artificially low values and then go on a run which hits all 5 HR zones in order to have new automatic values populate (if they are lower than the old max values). Is this correct?
- I am planning to re-run the LTHR Test this afternoon, and throw in some max-effort intervals afterward in order to try to double-check my MaxHR. What should I set my HR Zones to before this test, and are there any other HR-related settings that I need to have set a specific way before/after in order to have things work correctly?
- Based on posts here, it is sounding like I should set the HR Zones to be based on %MaxHR and manually adjust LTHR to something low like 150bpm if I want the test to make an accurate estimate if I suspect that it will be less than 167bpm.
- During the LTHR test, should automatic MaxHR and/or LTHR be left on or off?
- I have never seen a Lactate Threshold Pace value be given. It is always blank ("--:--"), despite having a LTHR. What could be causing this?
- Up until the start of the year, I had a Vivoactive3 and some health data was imported from that I think. Could there be some issue related to that which I may need to do a hard-reset to clear out? I can live with losing all of my health/performance data since should only take ~1 month to get things up to date again, but obviously I'd prefer to avoid this.
Thanks!
