I'm a bit old school (and old age too ), so when I think of heart rate zones, I usually think of the "typical" 5 zones based on %max heart rate. I've noticed folks here quite often use zones based on %lactate threshold. What are the advantages and disadvantages of using one versus the other?
If I understand this correctly, I could see where %LTHR based zones might be beneficial if auto detection is enabled, and occasionally you get a new LTHR, and zones are adjusted accordingly. That, as opposed to max heart rate, where a little more effort would be required to get a new max heart rate (via auto detection).
I had read a post sometime last year that discussed this in much more detail, but as much as I searched, I cannot find that post.
I'm just trying to understand zones based on %max heart rate and %lactate threshold, and determine the pros and cons of each. My understanding mentioned above could be totally wrong, hence the reason for the post.
Thanks
