Multisport SwimRun and transition issues
I created a new Swim Run profile (with Open swimming first and Run second on repeat, not trail running first as per the default swimrun profilte) with the Transition option / setting to on.  I was dry testing this set-up and the transition time was not being recorded at all.
I thought it may be due to not actually swimming and running but when I did go for my exercise this morning the following issues appeared.
1. The transition time  was not recorded at all.  (This was also the same for my friend with the Garmin 745).
2. The lap button was automatically "pressed", however I definitely did not press it.
3. In testing and also during the activity instead of immediately changing from the one activity that is Open water swimming to Run, or Run to Open water swimming the screen below showed up.  The time visible on this screen as per the screenshot, was always 1.23 or 1.22 (it happened a few times), and this also happened to another one of my friends also with the 955.
So all 3 of us this morning has Swim Run issues!!!!
The transition in the Triathlon activity works perfectly for all of us...
Regards,
Russel
