Now available to download…
I already have and report 3 bugs in the first 5 minutes. The Beta on my Fenix 7 solar works like a charm. I'm starting to hate the forerunner series and team development
Weren't the beta bugs supposed to be reported/discussed in the beta forum?
Could anyone try if navigating to a saved location is fixed? Don't see anything listed concerning this and if this is still there I'm really officially utterly freaking disappointed and p*ssed with garmin…
mostly satisfied, but check out the bug reports. i just discovered a new bug where the backlight is activating on gesture even though it's midday and i have to only activate supposedly after sunset. this is a newly introduced bug in the beta, unlike the other bugs i've reported that already existed in prior firmwares.
Like the addition of wrist-based running dynamics a lot! Only shortcoming is lack of GCT balance. Can watch not be able to differentiate left/right GCT by just counting odd/even GCT number? Does HRM have left/right poistion sensor to provide these balance data?
Notice that the map panning button in history activity finally work in Beta 15.09, however without touch-drag pan feature, review history map is basically useless.
i've only done one run with the wrist based dynamics, but with a very small sample size, the Vertical Oscillation and Ratio measured (high 8's for both) is significantly different than the several runs i've done with my HRM Pro Plus (low 7s). i don't wear the Pro Plus often because it's just not comfortable relative to my older simple HRM straps but on occasion use it to check out those dynamics. the ground contact numbers are very similar.
i'll collect more data, but will be curious if others have found similar discrepancies. (i speculate it may be wrist vs chest location and i'm guessing chest is more stable and reliable as a measure)
