but I say .... after 9 months still some bugs! come on Garmin! during the activity summary, the map cannot be moved but only zoomed and vice versa.
I just saw your post after replying in the battery drain for 11.23.
"Still battery drain happens on firmware 14.17. I wanted to test that earphones bug, is it just on spotify or on local music too. It played for over 8 minutes without dropping.
I started a run and music. After 8 minutes discarded the run and turned off the earphones in the menu and turned on airplane mode back on. 66% to 64%.
Just woke up, the battery went from 64% to 40% in about 10 hours.
Again I write (like the last summer) - C'mon Garmin, fix it please!"
Maybe better luck if replied in more posts:)
you won't get any luck doing anything on these forums - garmin don't really read them let alone respond.
log your bugs with garmin support. then chase them relentlessly until they fix them. that is the only way to get action.
oh and maybe spread the word as to how unreliable garmin devices have become - that may kick them into actually doing something too.
