I turned the daily suggestion workout prompt on but the daily suggested workout prompts never come up.....this is after I finished a 10k running Garmin coach training plan so instead of the training plan, daily workouts suggestions should come up.
I fixed it! I did two things, don't know which one solved (or maybe both were needed anyway):
1. Plugged my Garmin on my computer USB. Wento into folder Garmin/Workouts and deleted everything there
2…
I have the exact same issue, stopped showing after I completed a training plan. couldn't find a way to fix.
I event tried to disable and re-enable the workout prompts in config but still not working…
I haven't had any issues with my 955 (never used the Garmin coach), but my wife has a 255 and has the exact same issue you're describing and it was right after completing a Garmin coach training plan.…
2. Started a new training plan and then finished it from garmin connect without doing any workout
after restarting my watch the suggestion was there
hope this helps anyone with the same issue
Had this problem and solved it like this:
Check all the workouts and coach plans that you have on your watch (go to run settings and select workouts or training) . Also delete from garmin connect, as sometimes it do not sync together. Delete all of them. This solved my issue. Somehow the daily suggestions are obstructed by the other plans suggestions.
I also haven't got prompts since I finished my training plan (about 2 months ago). What fixed it for me was that on my forerunner 255 I went to Run→Training → Workouts→ Daily suggestions → Settings → Workout prompt →changed from "on" to "off" (then I restarted the watch) and then "on" again.
