Charged the watch to 100% and in one day with an 40 minute run the watch dropped down to 86%! I didn’t listen to music and was in the smart gps mode! Also I didn’t connect my phone and Wi-Fi! I have the backlight at 10%!
It will probably stabilize after the second charge on the current firmware. That is the case in most of mine fw updates. + turn it off/restart by holding the light button after the update. If it isn't the first charge after update, then someone else can maybe help. I was loosing about 6% (maybe percentage more) an hour if I recall correctly on some of the earlier firmwares, but with the backlight off. If the light is on during the whole hour, then that could be normal consumption.
