I have no idea what triggered it, but my fr955 is not usable any more: It keeps rebooting. I tried several key combinations, but nothing helped to break the endless reboot loop. Does any one knows a trick?
I have the solution:
Factory Reset Instructions
Power off (press and hold Light)
Press and hold Start/Stop and Lap/Reset
Press and hold Light (three buttons should now be pressed in).
After first beep, release…
I have the same now with my FR955. It shows the green Garmin triangle, then after a while it reboots. This repeats endlessly. I tried the suggestion above to restore to factory default settings. But unfortunately…
After first beep, release Start/Stop.
After second beep, release Lap/Reset.
Release Light.
Watch is now reset.
This was done in the shop where I bought the fr955.
The watch is now working again!
I have the same now with my FR955. It shows the green Garmin triangle, then after a while it reboots. This repeats endlessly. I tried the suggestion above to restore to factory default settings. But unfortunately, during that process (you see the cogwheel with a progress bar), the watch reboots again, and the endless loop is repeated. Does anyone know of any other ways to bring the watch back to life again?
Also, I tried connecting to a computer, but then the computer says the watch is not connected. Before I tried all these things, the watch has been charged for a few hours.
Exact same issue for me. Any advice Garmin-Kevin?
