Briefly show map at turn prompts?
Hello, I’m wondering if the watch can show briefly the map when it shows an alert for direction change (called turn prompt)? For example it works like this on the edge 1030, the map is shown when the alert prompts (even if we are on a data screen). Would be great to have the same on the 955. When hiking I usually use a data screen with distance, time, etc… every time I receive a turn prompt alert I see the arrow at the bottom of the screen but it would be better to see the map (like 10 seconds). The arrow only is most of the time not enough. Maybe this is feasible but I cannot find the setting. Thanks!
