I have a stryd and was wondering how garmin power would align with it... I know the actual values would differ, but if the trends align and perhaps a correction is possible one could actually use them interchangeably. Anyway, using an existing R library for processing fit files I analyzed a recent interval run.
I used the stryd in standalone mode so downloaded the .fit from the stryd powercenter and the .fit from connect and compared them seperately (didn't quickly find a field to use the stryd as an external sensor in order to compare them in connect... but was still interested in the corrections possibility anyway so post processing was a requirement anyway)
RAW values:
:fill(white):strip_exif()/f/image/qRcnU69UbTkKKxWclxVEQjqH.png?f=user_large)
Correction factor applied:
:fill(white):strip_exif()/f/image/zmXrge4F94kCmwAjmc0uOKKf.png?f=user_large)
The correction factor was simply calculated by the avg of the correction factor for each 'overlapping' datapoint.. Probably not the best but hey ;)
Anyway, I guess the conclusion is the same as with HR... Thery correspond pretty well even though the garmin power lags compared to stryd (which makes sense). With higher values the differences are larger (a single correction factor is to simple I guess, maybe a scalable one is better) but I guess it's actually quite usable.
Not interchangeable as of now but still... Interesting to see. Just thought I'd share ;)
