Unfortunately VO2Max is no longer calculated with the non-Beta.12.27 no calculation13.15 calculation13.21 no calculationWhat can I do?
Hello,after resetting the clock, VO2Max appears after the third run. Question therefore solved.
It's only calculated in certain conditions, like a minimum distance or time run.
All the time you had 12.27 it was never calculated?
Mine is calculated and has been across all those FW versions
Are you running at least 2-3 times outdoor with GPS? Indoor run and threadmill run do not apply for VO2 calculation
