Virtual Run use stryd for pace and distance
When doing a virtual run I can use my footpod stryd for power. However, Garmin doesn't use the footpod for distance/speed so my watch says 4:30/km but the treadmill + zwift show 5:30/km (correct because Zwift is reading my footpod speed).
I don't mind calibrating after the session but on my old forerunner 245m there was no need to calibrate manually as I could tell my watch hey just listen to stryd and all my values lined up.
  • Have you connected to your Stryd as a footpod by selecting Settings (hold UP) > Sensors & Accessories? (Stryd accepts multiple connections, so you can connect to it as both a footpod and a power sensor.)
    Once you do that, you should change the footpod settings so that Speed and Distance are set to Indoor (or Always, if you prefer).
