Hi all,
1. I recently got the FR 955 Solar. This is my first garmin watch. I went on a 7.5 km run 2 days ago but my watch showed the distance extra by 600 mtr, i.e. 8.1 km. The average pace was also off by more than a minute per km. I have been running on the route for a few years now so I know the distance of the route very well. I have been running with Samsung Galaxy Watch 3 earlier & had no problems distance wise.
2. I went online & searched for troubleshooting steps. As per the steps suggested by garmin, I made the following changes in watch settings :-
* I confirmed my GPS was set to All + multi band.
* I switched data recording to 'every second'.
* I enabled 3D speed & 3D distance.
* I waited for GPS bar to get a fix (green color) & waited an additional 1 min before starting my run.
3. After all the above, I went on a 6.2 km previously measured route the next morning with clear sky & no tall buildings around. I immediately noticed that each km being recorded by the watch was way short & hence the pace was way higher. The total distance reflected on the watch after the run was 7.54 km. It measured the the distance incorrectly by showing 1.3 km extra which is not the case as the route is 6.2 km.
4. The route as shown on the map in garmin connect app was spot on & traced my route perfectly. It is only the measured distance & pace that was on a higher side.
5. If anyone has any suggestion to fix the issue I'll be grateful.
