A diffrent maps than the marked ones
Hello
The problem is that no matter which one maps i have marked to be set on i see them changing only in Map mode, but when i start for example hiking and choose Map tab - i always see the same (basic?) map layer. It makes uploading OSM maps pointless, because you cant navigate with them and even see them in Map tab while Hiking or something.
Photos from Map mode and from Hiking mode - Map tab. Both with the same maps layers marked in Maps config.
