Hello,
i am not sure if I understand the touch function for zoom/panning correct.
In the manual i found this one:
Saving or Navigating to a Location on the Map
You can select any location on the map. You can save the location or start navigating to it.
I understood this the following:
i have an active activity e.g. hiking and one data page for the map, when i go to the map page i tap in the map, the cross appears and i have the posibility to zoom and pan the map?
Did i understood this correct?
This is definitly not working for me. When i want to zoom/pan, i have to choose the second function described in the manual and use the buttons, which is annoying:
To use the buttons, hold UP , select Pan/Zoom, and press UP or DOWN to zoom in or out.
Here it is described
Did i understood this correctly? Does it work for anyone or is this a bug?
Thanks!
