After installing 12.23, rebooting several times then charging my watch I now see a battery drain of ~5% per hour without any activities. Which is to say my watch will last less than a day if charged 100% and I don’t record any gps activities. I’m on iPhone 12 Pro (iOS 16)
The watch also seems to run significantly slower, hanging between screens.
If you already installed it and found this post, I’m sorry. Upvote or comment and hopefully Garmin will fix this soon. If you haven’t installed it yet, don’t.
UPDATE:
There are currently two options to prevent this issue: 1) disable Bluetooth and manually sync via WiFi. 2) disable Strava live segments in Garmin Connect by going to settings>training>segments> click the 3 dots and switch to garmin segments. This is likely why not all users are seeing the battery drain issue.
