I have a FR955 and EDGE 1040 with physio true-up tuned on.
However, the training status is different for both: https://photos.app.goo.gl/zL42mhVX3QFaC9J27
Is this normal or do i miss something?
kr
Jonas
kr
Jonas
I purchased 955 last week for daily wear, hiking, squash, all day HR, sleep tracking, etc... but use 830 for cycling.
Same issue as the OP... Training Status doesn't combine the activities from the two devices?
Also, in Garmin Connect 'My Day', it shows the cycling activity uploaded. When you click into it it shows 450 calories. But when you look into the Calories widget on main page it only says 59 active calories.
What worked for me is to make sure that Physio true up also is checked at connect.garmin:
See here as well, for the other places it might show up:
https://support.garmin.com/en-US/?faq=EjPECQK58qA0xzJ5X74vm7
I don't recall which one was not clicked for my 830, but making sure they all were turned on finally worked for me.
Also just received a new 955 (thanks to Garmin's superb customer service!!!), and it took a bit to get the true up to work. Not sure if it helped, but I turned it on and off a few times on the 830.
