Hi guys. I mentioned somewhere that I am not getting turn by turn navigation when using Komoot. Tested today. Polar Grit X shows turns, Garmin no. I wanted to retire Polar:)
I use it in offline mode with downloaded routes. If I go for a run or bike I wait 2 seconds till the route loads and it show below the name of the activity.
I get notification that the route was found and course finished, but nothing in between, not a single turn.
I found this on forum for FR245:
"The answer to the problem is very simple and can be found on the Komoot website: "Turn-by-turn navigation arrows: At the moment, no Garmin devices are capable of showing turn-by-turn navigation arrows on the device screen when using the IQ app only. If your device contains maps and is able to recalculate the route, the Tour will be adapted to the Garmin maps. In this case you will see the instruction arrows provided by Garmin." The Forerunner 245 does not have maps. That's it. It does not finally explain why slightly wrong instructions come up but OK."
Is that true for FR955 also? I think it had shown turns on my first run when I got it. I don't want to reset it again and setup all activities and data fields again.
Komoot was uninstalled then reinstalled, but with no luck.
Another small issue I found out is also Alert/Notification - when it is big (values) it goes a little bit out of bounds, out of display.
I set 1 hour notification, and after 1 hour it notified me in form "1 : 00 : 00" where 1 was partially cut on the left side of the display.
