I noticed this last night, and not sure if others have seen the same thing. My solar ring seems to be made up of two half rings that are then put together. Last night, I had the backlight on in a dark room and noticed that the backlight is showing between the two half rings. I am pretty sure this is not supposed to be happening and will most likely talk with support to make sure, but curious if others have seen the same thing.
Adding a photo of what I am seeing. You can see two white lines on the bezel right around the middle point.
