I found that running power on the 955 works well. However, it always says that wind conditions are "disabled". Has anyone managed to enable wind conditions to be part of the calculations. How is this done? I could not find a setting anywhere.
Wind data is enabled on my Fenix 7 as it is a native device. However, I also have the HRM- Run strap that is suppose to also be a compatible device. On my runs where I don’t use the strap I’ve had no issues. But I wore my HR strap on a road run on Thursday and it shows enabled. However, wearing it today on a trial run with 9mph winds and it shows disabled. I looked on my watch under the activity and everything is enabled as it should and is set to Smart connect which auto chooses the recording method based on connected accessories. Under the Help option is says that Wind is supposed to be activated by Default and based on GPS heading and other variables like weather conditions determines if it’s enabled or not. I contacted support and they are clueless saying they’ll pass it on. I don’t understand the inconsistencies with Garmin devices.
